[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.describe/main.c |no clones | 0 monsters | 0 warnings
Fri Sep 15 04:46:52 EDT 2006
Hello brad,
ANALYSIS
raster/r.describe/main.c functions
main (Begins at: 26 Ends at: 126)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |     101 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
