[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.describe/dumplist.c
|no clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 15 04:46:52 EDT 2006
Hello brad,
ANALYSIS
raster/r.describe/dumplist.c functions
long_list (Begins at: 24 Ends at: 46)
Complexity: | 4 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 5 | | OK |
LOC: | 23 | | OK |
metrics are OK
compact_list (Begins at: 48 Ends at: 79)
Complexity: | 5 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 32 | | OK |
metrics are OK
show (Begins at: 81 Ends at: 114)
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 34 | | OK |
at least 1 values are close to an outlier please consider revising code
compact_range_list (Begins at: 116 Ends at: 139)
Complexity: | 7 | | OK |
LOC: | 24 | | OK |
range_list (Begins at: 141 Ends at: 162)
CalledNBR: | 6 | | OK |
LOC: | 22 | | OK |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
