[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.compress/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 15 04:46:51 EDT 2006
Hello brad,
ANALYSIS
raster/r.compress/main.c functions
main (Begins at: 47 Ends at: 87)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 41 | | OK |
metrics are OK
process (Begins at: 91 Ends at: 163)
Complexity: | 11 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 34 | * | |
LOC: | 73 | | OK |
metrics are OK
doit (Begins at: 166 Ends at: 247)
Complexity: | 12 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 30 | | OK |
LOC: | 82 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
