[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.contour/cont.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 15 04:46:51 EDT 2006
Hello brad,
ANALYSIS
raster/r.contour/cont.c functions
contour (Begins at: 40 Ends at: 214)
Complexity: | 17 | * | |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 42 | * | |
LOC: | 175 | * | |
at least 1 values are close to an outlier please consider revising code
getnewcell (Begins at: 222 Ends at: 239)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
newedge (Begins at: 243 Ends at: 265)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
findcrossing (Begins at: 273 Ends at: 327)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 55 | | OK |
metrics are OK
getpoint (Begins at: 333 Ends at: 378)
Complexity: | 10 | | OK |
LOC: | 46 | | OK |
metrics are OK
checkedge (Begins at: 383 Ends at: 391)
ParamNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
