[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Reset_colors.c |4 clones ( Color_table.c main.c graphics.c graphics.c Color.c command.c Reset_colors.c )| 0 monsters | 0 warnings
Tue Sep 19 06:39:51 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/Reset_colors.c functions
COM_Reset_color (Begins at: 6 Ends at: 11)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
COM_Reset_colors (Begins at: 13 Ends at: 23)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  COM_Reset_color  _float_Reset_colors  _fixed_Reset_colors  COM_Reset_colors
In lib/driver/Reset_colors.c clones of  COM_Reset_colors are:
	display/drivers/lib/Reset_colors.c  COM_Reset_colors
In lib/driver/Reset_colors.c clones of  _fixed_Reset_colors are:
	lib/driver/Reset_colors.c  _float_Reset_colors
	display/drivers/lib/Reset_colors.c  _float_Reset_colors
	display/drivers/lib/Reset_colors.c  _fixed_Reset_colors
In lib/driver/Reset_colors.c clones of  _float_Reset_colors are:
	lib/driver/Reset_colors.c  _fixed_Reset_colors
In lib/driver/Reset_colors.c clones of  COM_Reset_color are:
Threshold GRASS6 key metrics values at 2006-09-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
