[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/init.c |no clones
	| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Tue Sep 19 06:39:51 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/init.c functions
LIB_init (Begins at: 32 Ends at: 73)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
