[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.in.ascii/main.c |1 clones ( main.c )| 0 monsters | 0 warnings
Sun Sep 24 12:38:32 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.in.ascii/main.c functions
fatalError (Begins at: 54 Ends at: 63)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
setParams (Begins at: 74 Ends at: 99)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
getParams (Begins at: 104 Ends at: 115)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
readHeaderString (Begins at: 120 Ends at: 130)
ParamNBR:     |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
openAscii (Begins at: 135 Ends at: 163)
CalledNBR:    |      15 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
asciiToG3d (Begins at: 170 Ends at: 216)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      47 |       |      OK |
metrics are OK
main (Begins at: 221 Ends at: 273)
CalledNBR:    |      19 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  fatalError
In raster3d/r3.in.ascii/main.c clones of  fatalError are:
	lib/g3d/g3dclose.c  G3d_closeOld
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
