[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.to.rast/main.c
|1 clones ( main.c main.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 24 12:38:32 EDT 2006
Hello soeren,
ANALYSIS
raster3d/r3.to.rast/main.c functions
fatal_error (Begins at: 48 Ends at: 66)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 19 | | OK |
metrics are OK
set_params (Begins at: 71 Ends at: 98)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
g3d_to_raster (Begins at: 103 Ends at: 173)
Complexity: | 12 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 71 | | OK |
metrics are OK
open_output_map (Begins at: 178 Ends at: 187)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 10 | | OK |
metrics are OK
close_output_map (Begins at: 192 Ends at: 196)
ParamNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
main (Begins at: 201 Ends at: 361)
Complexity: | 21 | * | |
CalledNBR: | 62 | ** | Warning |
LOC: | 161 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
setParams
In raster3d/r3.to.rast/main.c clones of setParams are:
raster3d/r3.cross.rast/main.c SetParameter
Threshold GRASS6 key metrics values at 2006-09-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
