[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.recode/recode.c |no clones | 0 monsters | 0 warnings
Sun Sep 24 13:49:44 EDT 2006
Hello jachym,
ANALYSIS
raster/r.recode/recode.c functions
do_recode (Begins at: 22 Ends at: 80)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
process_row_ii (Begins at: 82 Ends at: 90)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
process_row_if (Begins at: 92 Ends at: 100)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_id (Begins at: 102 Ends at: 110)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_fi (Begins at: 112 Ends at: 120)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_ff (Begins at: 122 Ends at: 130)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_fd (Begins at: 132 Ends at: 140)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_di (Begins at: 142 Ends at: 150)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_df (Begins at: 152 Ends at: 160)
LOC:          |       9 |       |      OK |
metrics are OK
process_row_dd (Begins at: 162 Ends at: 170)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-24 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
