[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.coin/make_coin.c |1
clones ( make_coin.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Sep 26 04:41:39 EDT 2006
Hello jachym,
ANALYSIS
raster/r.coin/make_coin.c functions
make_coin (Begins at: 32 Ends at: 190)
Complexity: | 15 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 42 | * | |
LOC: | 159 | * | |
metrics are OK
cmp (Begins at: 192 Ends at: 201)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
collapse (Begins at: 204 Ends at: 222)
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cmp
In raster/r.coin/make_coin.c clones of cmp are:
raster/r.random.cells/init.c comp_array
Threshold GRASS6 key metrics values at 2006-09-26 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
