[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.setup/main.c |no clones | 0 monsters | 0 warnings
Wed Sep 27 05:10:50 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/main.c functions
main (Begins at: 38 Ends at: 123)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
get_pwd (Begins at: 129 Ends at: 139)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-27 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
