[GRASS-QA] GRASS QA: hamish | ./grass6/lib/display/draw.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Sep 28 05:28:14 EDT 2006
Hello hamish,
ANALYSIS
lib/display/draw.c functions
D_set_clip_window (Begins at: 60 Ends at: 95)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 36 | | OK |
metrics are OK
D_set_clip_window_to_map_window (Begins at: 97 Ends at: 118)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
D_set_clip_window_to_screen_window (Begins at: 120 Ends at: 142)
LOC: | 23 | | OK |
metrics are OK
D_cont_abs (Begins at: 144 Ends at: 179)
ParamNBR: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 36 | | OK |
metrics are OK
D_cont_rel (Begins at: 181 Ends at: 196)
CalledNBR: | 1 | | OK |
LOC: | 16 | | OK |
metrics are OK
D_move_abs (Begins at: 198 Ends at: 216)
CalledNBR: | 0 | | OK |
LOC: | 19 | | OK |
metrics are OK
D_move_rel (Begins at: 218 Ends at: 232)
LOC: | 15 | | OK |
metrics are OK
clip (Begins at: 234 Ends at: 373)
Complexity: | 27 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 140 | * | |
at least 1 values are close to an outlier please consider revising code
line_eq (Begins at: 375 Ends at: 383)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
