[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.resamp.stats/main.c
|1 clones ( main.c main.c )| 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Sep 28 05:28:14 EDT 2006
Hello brad,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 26 Ends at: 43)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
find_method (Begins at: 45 Ends at: 54)
LOC: | 10 | | OK |
metrics are OK
main (Begins at: 56 Ends at: 237)
Complexity: | 8 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 68 | ** | Warning |
LOC: | 182 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
build_method_list
In raster/r.resamp.stats/main.c clones of build_method_list are:
raster/r.series/main.c build_method_list
Threshold GRASS6 key metrics values at 2006-09-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
