[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.pixel/cellclip.c |no clones | 0 monsters | 4 warnings
Thu Sep 28 21:39:56 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.pixel/cellclip.c functions
cell_clip_drv (Begins at: 33 Ends at: 168)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      23 |       |      OK |
LOC:          |     136 |     * |         |
at least 1 values are close to an outlier please consider revising code
is_not_empty_buffer (Begins at: 170 Ends at: 190)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
center_is_not_null (Begins at: 198 Ends at: 217)
LOC:          |      20 |       |      OK |
metrics are OK
cell_clip (Begins at: 225 Ends at: 441)
Complexity:   |      30 |    ** | Warning |
CalledNBR:    |      43 |     * |         |
LOC:          |     217 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
get_rich (Begins at: 443 Ends at: 468)
ParamNBR:     |       3 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
compar (Begins at: 476 Ends at: 480)
Complexity:   |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-28 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
