[GRASS-QA] GRASS QA: hamish |
./grass6/raster/r.le/r.le.setup/main.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Sep 28 21:58:13 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.setup/main.c functions
main (Begins at: 38 Ends at: 123)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 32 | | OK |
LOC: | 86 | | OK |
metrics are OK
get_pwd (Begins at: 129 Ends at: 139)
Complexity: | 2 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 11 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
