[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.vpoints/drawcell.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Apr  2 12:25:32 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.vpoints/drawcell.c functions
drawcell (Begins at: 7 Ends at: 101)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      95 |       |      OK |
metrics are OK
re_fresh_rast (Begins at: 104 Ends at: 118)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
