[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.mapcalc/evaluate.c
	|2 clones ( evaluate.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Mon Apr  2 22:57:23 EDT 2007
Hello glynn,
ANALYSIS
raster/r.mapcalc/evaluate.c functions
allocate_buf (Begins at: 21 Ends at: 24)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
set_buf (Begins at: 26 Ends at: 29)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
initialize_constant (Begins at: 33 Ends at: 36)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
initialize_variable (Begins at: 38 Ends at: 41)
LOC:          |       4 |       |      OK |
metrics are OK
initialize_map (Begins at: 43 Ends at: 48)
LOC:          |       6 |       |      OK |
metrics are OK
initialize_function (Begins at: 50 Ends at: 63)
LOC:          |      14 |       |      OK |
metrics are OK
initialize_binding (Begins at: 65 Ends at: 69)
LOC:          |       5 |       |      OK |
metrics are OK
initialize (Begins at: 71 Ends at: 84)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
evaluate_constant (Begins at: 88 Ends at: 114)
Complexity:   |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
evaluate_variable (Begins at: 116 Ends at: 119)
LOC:          |       4 |       |      OK |
metrics are OK
evaluate_map (Begins at: 121 Ends at: 130)
LOC:          |      10 |       |      OK |
metrics are OK
evaluate_function (Begins at: 132 Ends at: 168)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
evaluate_binding (Begins at: 170 Ends at: 173)
LOC:          |       4 |       |      OK |
metrics are OK
evaluate (Begins at: 177 Ends at: 190)
LOC:          |      14 |       |      OK |
metrics are OK
error_handler (Begins at: 198 Ends at: 216)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
setup_rand (Begins at: 218 Ends at: 236)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
execute (Begins at: 238 Ends at: 319)
CalledNBR:    |      18 |       |      OK |
LOC:          |      82 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  evaluate  initialize
In raster/r.mapcalc/evaluate.c clones of  evaluate are:
	raster/r.mapcalc/evaluate.c  initialize
In raster/r.mapcalc/evaluate.c clones of  initialize are:
	raster/r.mapcalc/evaluate.c  evaluate
Threshold GRASS6 key metrics values at 2007-04-02 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
