[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_io.c |no clones | 0 monsters | 0 warnings
Wed Apr 4 03:09:52 EDT 2007
Hello glynn,
ANALYSIS
lib/raster/com_io.c functions
init_transport (Begins at: 143 Ends at: 159)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
R_open_driver (Begins at: 161 Ends at: 165)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R__open_quiet (Begins at: 167 Ends at: 171)
LOC:          |       5 |       |      OK |
metrics are OK
R_stabilize (Begins at: 173 Ends at: 176)
LOC:          |       4 |       |      OK |
metrics are OK
R_kill_driver (Begins at: 178 Ends at: 181)
LOC:          |       4 |       |      OK |
metrics are OK
R_close_driver (Begins at: 183 Ends at: 186)
LOC:          |       4 |       |      OK |
metrics are OK
R_release_driver (Begins at: 188 Ends at: 191)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
