[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Draw_point.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Apr  4 03:09:52 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Draw_point.c functions
PNG_draw_point (Begins at: 3 Ends at: 11)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-04 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
