[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/paths.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Apr 4 03:09:52 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/paths.c functions
G_mkdir (Begins at: 17 Ends at: 33)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_is_dirsep (Begins at: 35 Ends at: 50)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 16 | | OK |
metrics are OK
G_convert_dirseps_to_host (Begins at: 52 Ends at: 72)
LOC: | 21 | | OK |
metrics are OK
G_convert_dirseps_from_host (Begins at: 74 Ends at: 95)
LOC: | 22 | | OK |
metrics are OK
G_stat (Begins at: 97 Ends at: 112)
ParamNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
G_lstat (Begins at: 114 Ends at: 121)
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-04 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
