[GRASS-QA] GRASS QA: martinl | ./grass6/db/drivers/dbf/dbfexe.c |no clones | 3 monsters | 2 warnings
Fri Apr 6 05:51:20 EDT 2007
Hello martinl,
ANALYSIS
db/drivers/dbf/dbfexe.c functions
execute (Begins at: 42 Ends at: 309)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      55 |     * |         |
LOC:          |     268 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
get_col_def (Begins at: 312 Ends at: 336)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
eval_val (Begins at: 338 Ends at: 396)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
set_val (Begins at: 398 Ends at: 454)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
cmp_row_asc (Begins at: 459 Ends at: 492)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
cmp_row_desc (Begins at: 494 Ends at: 499)
Complexity:   |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
sel (Begins at: 503 Ends at: 617)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |     115 |       |      OK |
metrics are OK
eval_node (Begins at: 619 Ends at: 938)
Complexity:   |      72 |   *** | MONSTER |
LOC:          |     320 |   *** | MONSTER |
2 metric are OUT OF RANGE!
eval_node_type (Begins at: 940 Ends at: 1075)
Complexity:   |      44 |   *** | MONSTER |
LOC:          |     136 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
