[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Draw_line.c |no clones | 0 monsters | 0 warnings
Fri Apr 6 08:57:49 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Draw_line.c functions
store_xy (Begins at: 13 Ends at: 19)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
draw_line (Begins at: 21 Ends at: 110)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      90 |       |      OK |
metrics are OK
PNG_draw_line (Begins at: 112 Ends at: 135)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
