[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_parse_options.c |no clones | 0 monsters | 0 warnings
Fri Apr 6 13:29:51 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_parse_options.c functions
N_define_standard_option (Begins at: 42 Ends at: 110)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      69 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
