[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_les_assemble.c
|no clones | 4 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 6 13:29:51 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_les_assemble.c functions
N_alloc_5star (Begins at: 30 Ends at: 44)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
N_alloc_7star (Begins at: 46 Ends at: 63)
LOC: | 18 | | OK |
metrics are OK
N_alloc_9star (Begins at: 65 Ends at: 82)
LOC: | 18 | | OK |
metrics are OK
N_alloc_27star (Begins at: 84 Ends at: 104)
LOC: | 21 | | OK |
metrics are OK
N_create_5star (Begins at: 106 Ends at: 139)
ParamNBR: | 6 | * | |
CalledNBR: | 2 | | OK |
LOC: | 34 | | OK |
metrics are OK
N_create_7star (Begins at: 141 Ends at: 180)
ParamNBR: | 8 | ** | Warning |
LOC: | 40 | | OK |
at least 1 values are close to an outlier please consider revising code
N_create_9star (Begins at: 182 Ends at: 243)
ParamNBR: | 10 | *** | MONSTER |
LOC: | 62 | | OK |
1 metric are OUT OF RANGE!
N_create_27star (Begins at: 245 Ends at: 319)
ParamNBR: | 28 | *** | MONSTER |
CalledNBR: | 4 | | OK |
LOC: | 75 | | OK |
N_set_les_callback_3d_func (Begins at: 322 Ends at: 336)
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 15 | | OK |
metrics are OK
N_set_les_callback_2d_func (Begins at: 339 Ends at: 354)
LOC: | 16 | | OK |
metrics are OK
N_alloc_les_callback_3d (Begins at: 356 Ends at: 374)
LOC: | 19 | | OK |
metrics are OK
N_alloc_les_callback_2d (Begins at: 376 Ends at: 409)
LOC: | 34 | | OK |
metrics are OK
N_assemble_les_3d (Begins at: 411 Ends at: 745)
Complexity: | 39 | *** | MONSTER |
CalledNBR: | 47 | * | |
LOC: | 335 | *** | MONSTER |
2 metric are OUT OF RANGE!
N_assemble_les_2d (Begins at: 747 Ends at: 985)
Complexity: | 28 | ** | Warning |
CalledNBR: | 37 | * | |
LOC: | 239 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
N_callback_template_3d (Begins at: 987 Ends at: 1024)
ParamNBR: | 5 | * | |
LOC: | 38 | | OK |
metrics are OK
N_callback_template_2d (Begins at: 1026 Ends at: 1042)
ParamNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
