[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_gwflow.c |no clones | 0 monsters | 0 warnings
Fri Apr 6 13:29:51 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_gwflow.c functions
N_alloc_gwflow_data3d (Begins at: 38 Ends at: 66)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
N_free_gwflow_data3d (Begins at: 68 Ends at: 102)
ParamNBR:     |       1 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
N_alloc_gwflow_data2d (Begins at: 104 Ends at: 132)
CalledNBR:    |      12 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
N_free_gwflow_data2d (Begins at: 134 Ends at: 174)
LOC:          |      41 |       |      OK |
metrics are OK
N_callback_gwflow_3d (Begins at: 176 Ends at: 281)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |     106 |       |      OK |
metrics are OK
N_callback_gwflow_2d (Begins at: 283 Ends at: 401)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      44 |     * |         |
LOC:          |     119 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
