[GRASS-QA] GRASS QA: jachym | ./grass6/db/base/select.c |no clones | 0 monsters | 0 warnings
Fri Apr 6 13:39:07 EDT 2007
Hello jachym,
ANALYSIS
db/base/select.c functions
main (Begins at: 37 Ends at: 92)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
sel (Begins at: 95 Ends at: 168)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
parse_command_line (Begins at: 171 Ends at: 281)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     111 |       |      OK |
metrics are OK
get_stmt (Begins at: 284 Ends at: 305)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
stmt_is_empty (Begins at: 308 Ends at: 313)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
print_column_definition (Begins at: 316 Ends at: 325)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
