[GRASS-QA] GRASS QA: soeren | ./grass6/raster3d/r3.gwflow/main.c |no clones | 0 monsters | 2 warnings
Fri Apr 6 13:39:08 EDT 2007
Hello soeren,
ANALYSIS
raster3d/r3.gwflow/main.c functions
set_params (Begins at: 48 Ends at: 145)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      98 |       |      OK |
metrics are OK
main (Begins at: 150 Ends at: 345)
Complexity:   |      22 |     * |         |
CalledNBR:    |      82 |    ** | Warning |
LOC:          |     196 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
write_result (Begins at: 352 Ends at: 417)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      20 |       |      OK |
LOC:          |      66 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
