[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.font/main.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 07:41:20 EDT 2007
Hello glynn,
ANALYSIS
display/d.font/main.c functions
main (Begins at: 19 Ends at: 92)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
read_stroke_fonts (Begins at: 94 Ends at: 132)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
read_freetype_fonts (Begins at: 134 Ends at: 191)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
make_font_list (Begins at: 193 Ends at: 219)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
print_font_list (Begins at: 221 Ends at: 227)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
