[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/area.c |no clones | 4 monsters | 0 warnings
Sat Apr 7 09:06:13 EDT 2007
Hello glynn,
ANALYSIS
display/d.vect/area.c functions
darea (Begins at: 16 Ends at: 352)
Complexity:   |      48 |   *** | MONSTER |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      96 |   *** | MONSTER |
LOC:          |     337 |   *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
