[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.vect/plot1.c |no clones | 4 monsters | 0 warnings
Sat Apr 7 09:06:13 EDT 2007
Hello glynn,
ANALYSIS
display/d.vect/plot1.c functions
local_plot_poly (Begins at: 27 Ends at: 50)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
plot_polyline (Begins at: 55 Ends at: 76)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
plot_polygon (Begins at: 81 Ends at: 101)
CalledNBR:    |       5 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
plot1 (Begins at: 106 Ends at: 515)
Complexity:   |      67 |   *** | MONSTER |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      97 |   *** | MONSTER |
LOC:          |     410 |   *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
