[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/draw2.c |2 clones ( draw2.c )| 0 monsters | 1 warnings
Sat Apr 7 09:06:13 EDT 2007
Hello glynn,
ANALYSIS
lib/display/draw2.c functions
alloc_int (Begins at: 78 Ends at: 87)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
alloc_float (Begins at: 89 Ends at: 98)
LOC:          |      10 |       |      OK |
metrics are OK
dealloc_float (Begins at: 100 Ends at: 115)
ParamNBR:     |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
do_convert (Begins at: 117 Ends at: 128)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
dist_plane (Begins at: 130 Ends at: 133)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
interpolate (Begins at: 135 Ends at: 138)
ParamNBR:     |       4 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
clip_point (Begins at: 140 Ends at: 147)
Complexity:   |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
clip_plane (Begins at: 149 Ends at: 181)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
do_clip (Begins at: 183 Ends at: 206)
Complexity:   |       9 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
shift_count (Begins at: 208 Ends at: 211)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
shift_angle (Begins at: 213 Ends at: 216)
LOC:          |       4 |       |      OK |
metrics are OK
coerce (Begins at: 218 Ends at: 224)
LOC:          |       7 |       |      OK |
metrics are OK
euclidify (Begins at: 226 Ends at: 256)
LOC:          |      31 |       |      OK |
metrics are OK
do_ll_wrap (Begins at: 258 Ends at: 289)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      32 |       |      OK |
at least 1 values are close to an outlier please consider revising code
D_set_clip (Begins at: 291 Ends at: 313)
LOC:          |      23 |       |      OK |
metrics are OK
D_clip_to_map (Begins at: 315 Ends at: 332)
LOC:          |      18 |       |      OK |
metrics are OK
D_move_clip (Begins at: 334 Ends at: 353)
LOC:          |      20 |       |      OK |
metrics are OK
line_clip (Begins at: 355 Ends at: 380)
CalledNBR:    |      11 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
line_clip_ll (Begins at: 382 Ends at: 404)
LOC:          |      23 |       |      OK |
metrics are OK
D_cont_clip (Begins at: 406 Ends at: 422)
LOC:          |      17 |       |      OK |
metrics are OK
D_polydots_clip (Begins at: 424 Ends at: 455)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
polyline_cull (Begins at: 457 Ends at: 476)
CalledNBR:    |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
D_polyline_cull (Begins at: 478 Ends at: 490)
LOC:          |      13 |       |      OK |
metrics are OK
polyline_clip (Begins at: 492 Ends at: 498)
LOC:          |       7 |       |      OK |
metrics are OK
D_polyline_clip (Begins at: 500 Ends at: 512)
LOC:          |      13 |       |      OK |
metrics are OK
clip_polygon_plane (Begins at: 514 Ends at: 554)
LOC:          |      41 |       |      OK |
metrics are OK
polygon_clip (Begins at: 556 Ends at: 583)
LOC:          |      28 |       |      OK |
metrics are OK
D_polygon_clip (Begins at: 585 Ends at: 594)
LOC:          |      10 |       |      OK |
metrics are OK
box_clip (Begins at: 596 Ends at: 612)
CalledNBR:    |       9 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
box_clip_ll (Begins at: 614 Ends at: 627)
LOC:          |      14 |       |      OK |
metrics are OK
D_box_clip (Begins at: 629 Ends at: 638)
LOC:          |      10 |       |      OK |
metrics are OK
D_move (Begins at: 640 Ends at: 646)
LOC:          |       7 |       |      OK |
metrics are OK
D_cont (Begins at: 648 Ends at: 654)
LOC:          |       7 |       |      OK |
metrics are OK
D_polydots (Begins at: 656 Ends at: 660)
LOC:          |       5 |       |      OK |
metrics are OK
D_polyline (Begins at: 662 Ends at: 666)
LOC:          |       5 |       |      OK |
metrics are OK
D_polygon (Begins at: 668 Ends at: 672)
LOC:          |       5 |       |      OK |
metrics are OK
D_box (Begins at: 674 Ends at: 686)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  D_cont  D_move
In lib/display/draw2.c clones of  D_move are:
	lib/display/draw2.c  D_cont
In lib/display/draw2.c clones of  D_cont are:
	lib/display/draw2.c  D_move
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
