[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/parser.c |1 clones ( parser.c )| 1 monsters | 9 warnings
Sat Apr 7 09:21:14 EDT 2007
Hello markus,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 160 Ends at: 181)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 184 Ends at: 242)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 245 Ends at: 327)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 330 Ends at: 571)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      31 |       |      OK |
LOC:          |     242 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 574 Ends at: 626)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 628 Ends at: 893)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     266 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 896 Ends at: 946)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 948 Ends at: 1135)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      54 |     * |         |
LOC:          |     188 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1137 Ends at: 1153)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1155 Ends at: 1369)
CalledNBR:    |      71 |    ** | Warning |
LOC:          |     215 |    ** | Warning |
G_usage_html (Begins at: 1371 Ends at: 1606)
Complexity:   |      43 |   *** | MONSTER |
CalledNBR:    |      80 |    ** | Warning |
LOC:          |     236 |    ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1608 Ends at: 1719)
Complexity:   |      22 |     * |         |
CalledNBR:    |      46 |     * |         |
LOC:          |     112 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1721 Ends at: 1806)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
G_gui (Begins at: 1809 Ends at: 1838)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1841 Ends at: 1856)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1858 Ends at: 1887)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1889 Ends at: 1902)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1904 Ends at: 1931)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1936 Ends at: 1945)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1947 Ends at: 2007)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 2009 Ends at: 2046)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 2048 Ends at: 2090)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2092 Ends at: 2158)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2160 Ends at: 2200)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2202 Ends at: 2229)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2231 Ends at: 2254)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2256 Ends at: 2319)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2321 Ends at: 2359)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2362 Ends at: 2418)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2420 Ends at: 2448)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2450 Ends at: 2458)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2460 Ends at: 2550)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2552 Ends at: 2582)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2584 Ends at: 2641)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2643 Ends at: 2745)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
