[GRASS-QA] GRASS QA: markus | ./grass6/db/base/describe.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 12:36:44 EDT 2007
Hello markus,
ANALYSIS
db/base/describe.c functions
main (Begins at: 23 Ends at: 70)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      27 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
parse_command_line (Begins at: 73 Ends at: 123)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
