[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/text2.c |no clones | 0 monsters | 1 warnings
Sat Apr 7 20:19:16 EDT 2007
Hello glynn,
ANALYSIS
lib/driver/text2.c functions
remember (Begins at: 13 Ends at: 22)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
text_draw (Begins at: 24 Ends at: 44)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
text_move (Begins at: 46 Ends at: 56)
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
drawchar (Begins at: 58 Ends at: 121)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       5 |       |      OK |
LOC:          |      64 |       |      OK |
at least 1 values are close to an outlier please consider revising code
soft_text_ext (Begins at: 123 Ends at: 135)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       6 |     * |         |
LOC:          |      13 |       |      OK |
metrics are OK
get_text_ext (Begins at: 137 Ends at: 143)
ParamNBR:     |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
soft_text (Begins at: 148 Ends at: 164)
LOC:          |      17 |       |      OK |
metrics are OK
onechar (Begins at: 166 Ends at: 178)
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
