[GRASS-QA] GRASS QA: glynn | ./grass6/lib/pngdriver/Box.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 20:19:16 EDT 2007
Hello glynn,
ANALYSIS
lib/pngdriver/Box.c functions
PNG_Box_abs (Begins at: 4 Ends at: 42)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
