[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Color.c |no clones | 0 monsters | 0 warnings
Sun Apr 8 09:04:28 EDT 2007
Hello glynn,
ANALYSIS
lib/driver/Color.c functions
DRV_lookup_color (Begins at: 5 Ends at: 10)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
DRV_color (Begins at: 12 Ends at: 16)
ParamNBR:     |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
COM_Color_RGB (Begins at: 19 Ends at: 22)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
COM_Standard_color (Begins at: 24 Ends at: 33)
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
