[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/window.c |no clones | 0 monsters | 0 warnings
Sat Apr 7 20:34:52 EDT 2007
Hello glynn,
ANALYSIS
lib/display/window.c functions
D_new_window (Begins at: 60 Ends at: 118)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      12 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
D_new_window_percent (Begins at: 120 Ends at: 150)
CalledNBR:    |       5 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
D_set_cur_wind (Begins at: 152 Ends at: 225)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
D_get_cur_wind (Begins at: 227 Ends at: 260)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
D_show_window (Begins at: 262 Ends at: 297)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
D_get_screen_window (Begins at: 299 Ends at: 328)
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
D_check_map_window (Begins at: 330 Ends at: 390)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
D_reset_screen_window (Begins at: 392 Ends at: 419)
CalledNBR:    |       7 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
D_timestamp (Begins at: 421 Ends at: 461)
CalledNBR:    |      13 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
D_remove_window (Begins at: 463 Ends at: 477)
Complexity:   |       1 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
D_erase_window (Begins at: 479 Ends at: 486)
LOC:          |       8 |       |      OK |
metrics are OK
D_erase (Begins at: 488 Ends at: 505)
LOC:          |      18 |       |      OK |
metrics are OK
D_remove_windows (Begins at: 507 Ends at: 524)
LOC:          |      18 |       |      OK |
metrics are OK
D_full_screen (Begins at: 526 Ends at: 536)
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-07 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
