[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Color_table.c |no clones | 0 monsters | 0 warnings
Sun Apr 8 09:35:42 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Color_table.c functions
init_color_table (Begins at: 9 Ends at: 12)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_color_rgb (Begins at: 14 Ends at: 17)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_color_gray (Begins at: 19 Ends at: 22)
LOC:          |       4 |       |      OK |
metrics are OK
PS_lookup_color (Begins at: 24 Ends at: 29)
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-08 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
