[GRASS-QA] GRASS QA: glynn | ./grass6/lib/psdriver/Graph_set.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 8 09:35:42 EDT 2007
Hello glynn,
ANALYSIS
lib/psdriver/Graph_set.c functions
write_prolog (Begins at: 24 Ends at: 46)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
PS_Graph_set (Begins at: 48 Ends at: 89)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 42 | | OK |
metrics are OK
output (Begins at: 91 Ends at: 98)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
