[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.graph/do_graph.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 8 14:34:28 EDT 2007
Hello glynn,
ANALYSIS
display/d.graph/do_graph.c functions
set_graph_stuff (Begins at: 23 Ends at: 31)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 9 | | OK |
metrics are OK
set_text_size (Begins at: 33 Ends at: 45)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 13 | | OK |
metrics are OK
do_draw (Begins at: 47 Ends at: 73)
Complexity: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 27 | | OK |
metrics are OK
do_move (Begins at: 75 Ends at: 93)
LOC: | 19 | | OK |
metrics are OK
do_color (Begins at: 95 Ends at: 125)
Complexity: | 5 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
do_linewidth (Begins at: 127 Ends at: 140)
CalledNBR: | 5 | | OK |
LOC: | 14 | | OK |
metrics are OK
do_poly (Begins at: 143 Ends at: 200)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 58 | | OK |
metrics are OK
do_size (Begins at: 202 Ends at: 228)
LOC: | 27 | | OK |
metrics are OK
do_text_rotate (Begins at: 230 Ends at: 243)
LOC: | 14 | | OK |
metrics are OK
do_text (Begins at: 245 Ends at: 256)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 12 | | OK |
metrics are OK
check_alloc (Begins at: 258 Ends at: 291)
CalledNBR: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
do_icon (Begins at: 293 Ends at: 343)
CalledNBR: | 18 | | OK |
LOC: | 51 | | OK |
metrics are OK
do_symbol (Begins at: 345 Ends at: 443)
Complexity: | 11 | | OK |
CalledNBR: | 34 | | OK |
LOC: | 99 | | OK |
metrics are OK
set_last_color (Begins at: 446 Ends at: 458)
ParamNBR: | 4 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
