[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.path/select.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Apr 8 14:49:51 EDT 2007
Hello glynn,
ANALYSIS
display/d.path/select.c functions
path (Begins at: 18 Ends at: 156)
Complexity: | 19 | * | |
ParamNBR: | 5 | * | |
CalledNBR: | 54 | * | |
LOC: | 139 | * | |
metrics are OK
display (Begins at: 159 Ends at: 177)
Complexity: | 5 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 4 | | OK |
LOC: | 19 | | OK |
metrics are OK
coor_path (Begins at: 183 Ends at: 266)
Complexity: | 6 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 26 | | OK |
LOC: | 84 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
