[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_arrays.c |4 clones ( N_arrays.c )| 0 monsters | 0 warnings
Mon Apr 9 19:48:52 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_arrays.c functions
N_alloc_array_2d (Begins at: 69 Ends at: 119)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
N_free_array_2d (Begins at: 127 Ends at: 159)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
N_get_array_2d_type (Begins at: 161 Ends at: 176)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
N_get_array_2d_value (Begins at: 179 Ends at: 226)
Complexity:   |       8 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
N_is_array_2d_value_null (Begins at: 228 Ends at: 309)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      82 |       |      OK |
metrics are OK
N_get_array_2d_c_value (Begins at: 311 Ends at: 341)
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
N_get_array_2d_f_value (Begins at: 343 Ends at: 373)
LOC:          |      31 |       |      OK |
metrics are OK
N_get_array_2d_d_value (Begins at: 375 Ends at: 406)
LOC:          |      32 |       |      OK |
metrics are OK
N_put_array_2d_value (Begins at: 409 Ends at: 453)
CalledNBR:    |       1 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
N_put_array_2d_value_null (Begins at: 455 Ends at: 517)
CalledNBR:    |       7 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
N_put_array_2d_c_value (Begins at: 520 Ends at: 548)
Complexity:   |       4 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
N_put_array_2d_f_value (Begins at: 551 Ends at: 579)
LOC:          |      29 |       |      OK |
metrics are OK
N_put_array_2d_d_value (Begins at: 582 Ends at: 601)
LOC:          |      20 |       |      OK |
metrics are OK
N_print_array_2d_info (Begins at: 609 Ends at: 633)
CalledNBR:    |      10 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
N_print_array_2d (Begins at: 635 Ends at: 722)
LOC:          |      88 |       |      OK |
metrics are OK
N_alloc_array_3d (Begins at: 724 Ends at: 769)
ParamNBR:     |       5 |     * |         |
LOC:          |      46 |       |      OK |
metrics are OK
N_free_array_3d (Begins at: 777 Ends at: 804)
CalledNBR:    |       4 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
N_get_array_3d_type (Begins at: 806 Ends at: 823)
LOC:          |      18 |       |      OK |
metrics are OK
N_get_array_3d_value (Begins at: 826 Ends at: 876)
LOC:          |      51 |       |      OK |
metrics are OK
N_is_array_3d_value_null (Begins at: 879 Ends at: 959)
CalledNBR:    |       8 |       |      OK |
LOC:          |      81 |       |      OK |
metrics are OK
N_get_array_3d_f_value (Begins at: 962 Ends at: 989)
CalledNBR:    |       2 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
N_get_array_3d_d_value (Begins at: 992 Ends at: 1020)
LOC:          |      29 |       |      OK |
metrics are OK
N_put_array_3d_value (Begins at: 1023 Ends at: 1074)
LOC:          |      52 |       |      OK |
metrics are OK
N_put_array_3d_value_null (Begins at: 1077 Ends at: 1144)
LOC:          |      68 |       |      OK |
metrics are OK
N_put_array_3d_f_value (Begins at: 1147 Ends at: 1170)
Complexity:   |       2 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
N_put_array_3d_d_value (Begins at: 1173 Ends at: 1186)
LOC:          |      14 |       |      OK |
metrics are OK
N_print_array_3d_info (Begins at: 1194 Ends at: 1218)
CalledNBR:    |      11 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
N_print_array_3d (Begins at: 1220 Ends at: 1241)
Complexity:   |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  N_put_array_2d_f_value  N_put_array_2d_c_value  N_get_array_2d_f_value  N_get_array_2d_c_value
In lib/gpde/N_arrays.c clones of  N_put_array_2d_c_value are:
	lib/gpde/N_arrays.c  N_put_array_2d_f_value
In lib/gpde/N_arrays.c clones of  N_put_array_2d_f_value are:
	lib/gpde/N_arrays.c  N_put_array_2d_c_value
In lib/gpde/N_arrays.c clones of  N_get_array_2d_c_value are:
	lib/gpde/N_arrays.c  N_get_array_2d_f_value
In lib/gpde/N_arrays.c clones of  N_get_array_2d_f_value are:
	lib/gpde/N_arrays.c  N_get_array_2d_c_value
Threshold GRASS6 key metrics values at 2007-04-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
