[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gpde/N_arrays_calc.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Apr 9 19:48:52 EDT 2007
Hello soeren,
ANALYSIS
lib/gpde/N_arrays_calc.c functions
N_copy_array_2d (Begins at: 43 Ends at: 141)
Complexity: | 24 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 99 | | OK |
metrics are OK
N_norm_array_2d (Begins at: 143 Ends at: 212)
Complexity: | 18 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 70 | | OK |
metrics are OK
N_calc_array_2d_stats (Begins at: 214 Ends at: 297)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 9 | | OK |
LOC: | 84 | | OK |
metrics are OK
N_math_array_2d (Begins at: 299 Ends at: 417)
Complexity: | 23 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 119 | | OK |
metrics are OK
N_convert_array_2d_null_to_zero (Begins at: 419 Ends at: 483)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 65 | | OK |
metrics are OK
N_copy_array_3d (Begins at: 485 Ends at: 557)
Complexity: | 14 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 73 | | OK |
metrics are OK
N_norm_array_3d (Begins at: 559 Ends at: 623)
Complexity: | 15 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 65 | | OK |
metrics are OK
N_calc_array_3d_stats (Begins at: 625 Ends at: 718)
LOC: | 94 | | OK |
metrics are OK
N_math_array_3d (Begins at: 720 Ends at: 827)
Complexity: | 22 | * | |
CalledNBR: | 22 | | OK |
LOC: | 108 | | OK |
metrics are OK
N_convert_array_3d_null_to_zero (Begins at: 829 Ends at: 864)
Complexity: | 7 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 36 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
