[GRASS-QA] GRASS QA: martinl | ./grass6/imagery/i.rgb.his/openfiles.c |no clones | 1 monsters | 0 warnings
Wed Apr 11 11:16:38 EDT 2007
Hello martinl,
ANALYSIS
imagery/i.rgb.his/openfiles.c functions
openfiles (Begins at: 7 Ends at: 45)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      36 |     * |         |
LOC:          |      39 |       |      OK |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
