[GRASS-QA] GRASS QA: martinl | ./grass6/imagery/i.rgb.his/r2hmain.c |no clones | 0 monsters | 0 warnings
Wed Apr 11 11:16:38 EDT 2007
Hello martinl,
ANALYSIS
imagery/i.rgb.his/r2hmain.c functions
main (Begins at: 27 Ends at: 106)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
