[GRASS-QA] GRASS QA: martinl | ./grass6/imagery/i.his.rgb/closefiles.c |1 clones ( closefiles.c )| 0 monsters | 0 warnings
Wed Apr 11 11:22:58 EDT 2007
Hello martinl,
ANALYSIS
imagery/i.his.rgb/closefiles.c functions
closefiles (Begins at: 9 Ends at: 42)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  closefiles
In imagery/i.his.rgb/closefiles.c clones of  closefiles are:
	imagery/i.rgb.his/closefiles.c  closefiles
Threshold GRASS6 key metrics values at 2007-04-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
