[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.mapcalc/evaluate.c
|2 clones ( main.c main.c evaluate.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 18:53:26 EDT 2007
Hello glynn,
ANALYSIS
raster/r.mapcalc/evaluate.c functions
allocate_buf (Begins at: 21 Ends at: 24)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
set_buf (Begins at: 26 Ends at: 29)
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
initialize_constant (Begins at: 33 Ends at: 36)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
initialize_variable (Begins at: 38 Ends at: 41)
LOC: | 4 | | OK |
metrics are OK
initialize_map (Begins at: 43 Ends at: 48)
LOC: | 6 | | OK |
metrics are OK
initialize_function (Begins at: 50 Ends at: 63)
LOC: | 14 | | OK |
metrics are OK
initialize_binding (Begins at: 65 Ends at: 69)
LOC: | 5 | | OK |
metrics are OK
initialize (Begins at: 71 Ends at: 84)
Complexity: | 8 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
evaluate_constant (Begins at: 88 Ends at: 114)
Complexity: | 6 | | OK |
LOC: | 27 | | OK |
metrics are OK
evaluate_variable (Begins at: 116 Ends at: 119)
LOC: | 4 | | OK |
metrics are OK
evaluate_map (Begins at: 121 Ends at: 130)
LOC: | 10 | | OK |
metrics are OK
evaluate_function (Begins at: 132 Ends at: 168)
Complexity: | 9 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 37 | | OK |
metrics are OK
evaluate_binding (Begins at: 170 Ends at: 173)
LOC: | 4 | | OK |
metrics are OK
evaluate (Begins at: 177 Ends at: 190)
LOC: | 14 | | OK |
metrics are OK
error_handler (Begins at: 198 Ends at: 216)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
setup_rand (Begins at: 218 Ends at: 236)
Complexity: | 2 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 19 | | OK |
metrics are OK
execute (Begins at: 238 Ends at: 319)
CalledNBR: | 18 | | OK |
LOC: | 82 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
evaluate initialize
In raster/r.mapcalc/evaluate.c clones of evaluate are:
raster/r.mapcalc/evaluate.c initialize
In raster/r.mapcalc/evaluate.c clones of initialize are:
raster/r.mapcalc/evaluate.c evaluate
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
