[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.to.rast/raster.c |no clones | 0 monsters | 0 warnings
Fri Apr 13 18:53:26 EDT 2007
Hello glynn,
ANALYSIS
vector/v.to.rast/raster.c functions
begin_rasterization (Begins at: 35 Ends at: 86)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
configure_plot (Begins at: 90 Ends at: 133)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
output_raster (Begins at: 137 Ends at: 165)
CalledNBR:    |       5 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
set_cat (Begins at: 167 Ends at: 173)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
set_dcat (Begins at: 175 Ends at: 181)
LOC:          |       7 |       |      OK |
metrics are OK
move (Begins at: 183 Ends at: 189)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
cont (Begins at: 191 Ends at: 214)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
cell_dot (Begins at: 216 Ends at: 224)
LOC:          |       9 |       |      OK |
metrics are OK
dcell_dot (Begins at: 226 Ends at: 234)
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
