[GRASS-QA] GRASS QA: glynn | ./grass6/imagery/i.vpoints/main.c |1 clones ( main.c )| 0 monsters | 0 warnings
Fri Apr 13 18:59:40 EDT 2007
Hello glynn,
ANALYSIS
imagery/i.vpoints/main.c functions
main (Begins at: 29 Ends at: 161)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      55 |     * |         |
LOC:          |     133 |     * |         |
metrics are OK
quit (Begins at: 163 Ends at: 186)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
error (Begins at: 188 Ends at: 214)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  quit
In imagery/i.vpoints/main.c clones of  quit are:
	imagery/i.points/main.c  quit
Threshold GRASS6 key metrics values at 2007-04-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      87 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
