[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/area_poly1.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Apr 13 20:44:01 EDT 2007
Hello glynn,
ANALYSIS
lib/gis/area_poly1.c functions
Q (Begins at: 28 Ends at: 36)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
Qbar (Begins at: 38 Ends at: 61)
LOC: | 24 | | OK |
metrics are OK
G_begin_ellipsoid_polygon_area (Begins at: 63 Ends at: 105)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 43 | | OK |
metrics are OK
G_ellipsoid_polygon_area (Begins at: 107 Ends at: 154)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 48 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-04-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 87 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
